Home » Sponsored » Pi Speakers » horn for 2 inch driver
horn for 2 inch driver [message #64580] Wed, 03 November 2010 22:33 Go to next message
Hi Wayne,
I have a friend that has a pair of 2" compression drivers that he is not using. He will let me borrow then. But I need a horn. Do you know of any 2 inch horns that would be good for hi end home use? Maybe something that is smoothly curved from throat to mouth, and is currently available?
Thanks,
Tom
Re: horn for 2 inch driver [message #64583 is a reply to message #64580] Wed, 03 November 2010 22:44 Go to previous message
There are a bunch of good horns for 2" drivers. But to tell the truth, since I don't use any of them in my designs, I can't give you a specific recommendation. I personally prefer constant directivity horns but I stay away from horns with sharp edges in them. Some horns use diffraction edges to help set the pattern, but that tends to make them sound spitty.
Previous Topic: A Possible 2.5 PI?
Next Topic: 2Pi speaker plan?
Current Time: Fri Nov 13 13:14:18 CST 2026
