I know you hate t-nuts so [message #64015] |
Thu, 09 September 2010 17:20 |
steve f
Messages: 236 Registered: May 2009
Master |
Everybody hates hurricane nuts. Some aren't too fond of regular t-nuts. I've a bag of "barbed body insert nuts" that appear to be made of zinc. I'm mounting some Peerless XLS 10" woofers to Baltic plywood. My question is are these any good? T-nuts don't require quite as big of holes so close to the baffle hole. I don't have any of Bill's fancy threaded inserts. Your comments please.
Steve
T-Nuts [message #64018 is a reply to message #64017] |
Fri, 10 September 2010 00:03 |
Messages: 18675 Registered: January 2001
Yeah, the tangs will fold up if you beat them in, especially the cheap ones. But when I pull them in with a screw, I don't have any problem, even in strong baltic birch plywood. I think adding the dab of glue helps too, because the biggest problem is having one come loose.
This process works very well for me, and it's important to have a 100% solution in my basshorn subs because a failure would cause a major repair problem, possibly even turning a $3000 cabinet into scrap. The woofers are mounted internally, and you can't really get behind the panels to access the T-Nut once it is in place. It is a long way inside the cabinet, behind panels that are buried inside.
