Home » Audio » Thermionic Emissions » Cadet 3
Cadet 3 [message #8113] Tue, 24 February 2004 03:07 Go to next message
analogue is currently offline  analogue
Hi, I have a cadet 3 , its making alot of noise through the right channel. Anyone got any ideas.
It works fine through the tape input.
Re: Cadet 3 [message #8114 is a reply to message #8113] Tue, 24 February 2004 12:34 Go to previous messageGo to next message
Try the radio input.
See if the input tubes are bad?
or the output tubes?
-akhilesh
Re: Cadet 3 [message #8115 is a reply to message #8113] Tue, 24 February 2004 13:48 Go to previous messageGo to next message
I'm not familiar with the "Cadet 3" but if you'll describe it, I'll be glad to try and help you out. Have you checked the simple stuff like switches, plugs and cables? Do you have a schematic? Other than tape, what inputs work? Which inputs don't work? Auxiliary, CD, Radio or Phono? Magnetic phono inputs have an additional amplifier stage, but most other inputs usually share common circuitry.
Re: Cadet 3 [message #8116 is a reply to message #8113] Wed, 25 February 2004 02:37 Go to previous message
Hi , Cheers for the quick responces, i have sent it back to the shop.
The radio and disc inputs were very noisy especially through the right channel. tried moving valves around but it wasn't that.
Great forum
Cheers
Previous Topic: Preamp Kit recommendations
Next Topic: This may be interesting to some
Current Time: Sat Oct 17 11:50:57 CDT 2026
