Home » Audio » Silicon Valley » RE:What do I do with ground wire?
RE:What do I do with ground wire? [message #7930] Thu, 01 March 2007 16:19 Go to next message
robert maclean is currently offline  robert maclean
Hi,
I was wondering if any of you kind people would be able to help me answer a simple question.I have just come into possession of a Solid State KA2000A Trio Amplifier which has a ground wire,attached by a screw,coming out of the back,is it important and what do I attach it to? Sorry for my ignorance but,Iam a complete novice at such things and have no wish to get fried,cheers.
Re: RE:What do I do with ground wire? [message #7931 is a reply to message #7930] Fri, 02 March 2007 21:09 Go to previous messageGo to next message
I'm not framiliar with your brand of amp, but if you have phono inputs on it, it's usually the ground wire from a turntable.
HTH
Billw
Re: RE:What do I do with ground wire? [message #7933 is a reply to message #7930] Tue, 17 April 2007 06:50 Go to previous messageGo to next message
Ricardo is currently offline  Ricardo
Generally, any time I've seen a ground wire I've assumed it would be connected with good mechanical contact to a metal structure of something else that we know to be grounded.
I assume this amp doesn't have a three-prong plug?
Re: RE:What do I do with ground wire? [message #7934 is a reply to message #7931] Wed, 18 April 2007 13:56 Go to previous messageGo to next message
randle is currently offline  randle
Yeah I want to know what brand it is before I actually try to assist you with this problem. Because of course all amps are made differently.
Re: RE:What do I do with ground wire? [message #7937 is a reply to message #7930] Thu, 26 April 2007 10:08 Go to previous message
From what I was told, sometimes those wires are just there but at the same time they aren't what color is the wire?
Previous Topic: RAP500
Next Topic: Buzzing Yamaha CA400
Current Time: Fri Nov 27 09:53:02 CST 2026
