Home » Audio » Silicon Valley » Alesis amplifiers
Alesis amplifiers [message #7719] Fri, 03 September 2004 12:59 Go to next message
Hutch is currently offline  Hutch
Hi all, I am considering an amplifier for a second system and want some power. It will be used for the occasional party and so needs some guts. I was looking at Crown and QSC but also Alesis. What do you think about them? Hutch
Re: Alesis amplifiers [message #7720 is a reply to message #7719] Fri, 03 September 2004 15:10 Go to previous messageGo to next message
Stick with the Crown or QSC. Long time ago heard someone saying Alesis amps suck, he had one about 2 years old, and had it in the shop after the outputs blown on it twice. Not sure how he was driving it or what he was using it for. But the Crown or QSC will last for years to come.
Re: Alesis amplifiers [message #7721 is a reply to message #7720] Fri, 03 September 2004 15:32 Go to previous messageGo to next message
Cool.
Thanks -
Hutch
Re: Alesis amplifiers [message #7722 is a reply to message #7719] Sat, 04 September 2004 20:33 Go to previous message
I had a pair of RA300's. The output relays would hang up (no output) after only about 2 months use. I replaced them with Crowns.
Previous Topic: Odyssey
Next Topic: Great technical link to amp design
Current Time: Sat Oct 24 03:57:03 CDT 2026
