Home » Audio » Silicon Valley » please help me
please help me [message #7677] Mon, 15 March 2004 08:39 Go to next message
detwid is currently offline  detwid
i am making final decision for my little system.
My system will be moon ecilpse cd player, krell kav 400 and b&w nautilus 805 with all xlo and transperancy cable.
does each equipment blend well with each other? I listen to vocal and easy listening music , nor rock or hard music
Thank you very much
Re: please help me [message #7678 is a reply to message #7677] Mon, 15 March 2004 09:58 Go to previous messageGo to next message
Audio Jones is currently offline  Audio Jones
Is your room small? If so, that will be a fine little system for you that will sound nice with jazz and acoustic recordings.
Re: please help me [message #7679 is a reply to message #7678] Mon, 15 March 2004 23:51 Go to previous messageGo to next message
thank you for ur comments,
like u said, if in the future i change my room to a bigger one so this system cannot produce good music then. is it because of the speaker? Also another option i found out today is BAT integrated ( Valve) or audionet sam V2, so what u think it suit best for Nautilus 805, or krell kav 400
Re: please help me [message #7680 is a reply to message #7679] Tue, 16 March 2004 16:19 Go to previous messageGo to next message
The 805 is fine in a small room but you'll want different speaks if your room is large. It images well but gets washed out in big rooms.
Re: please help me [message #7681 is a reply to message #7680] Tue, 16 March 2004 19:28 Go to previous message
unfortunately my 805 cannot be replaced because of the budget now.
so krell kav400 may suit best? because it deliver top power compare to audionet sam v2 and BAT vk 300x. Is it a good decision get krell to drive 805, or my other 2 amp options works better?
Previous Topic: Low cost power
Next Topic: chip amps
Current Time: Fri Oct 16 17:11:25 CDT 2026
