Home » Sponsored » Pi Speakers » 2PI tower
2PI tower [message #62532] Thu, 06 May 2010 10:45 Go to next message
kongarne is currently offline  kongarne
Hi
now I start build 2pi tower, I use 3 / 4 mdf
but are the dimensions of the drawing inside?
If they are outside they will probably get a little less volume?
best regards
Arne Olav S.
Re: 2PI tower [message #62533 is a reply to message #62532] Thu, 06 May 2010 11:21 Go to previous message
The dimensions shown in the plan are outside dimensions. The difference in volume between cabinets made with 5/8" or 3/4" material is small and there is much more change caused by the electro-mechanical shift of the woofer at various power levels. If the alignment was so unstable it could be upset by a tiny fractional percentage of interior volume shift, the speaker would sound vastly different at various power levels. So don't get hung up on the small difference of internal volume between various panel thicknesses.
Previous Topic: 4pi - like
Next Topic: 3 Pi - Could it work for me?
Current Time: Mon Oct 26 14:06:32 CDT 2026
