Home » Sponsored » Pi Speakers » 8 Pi horn and woofer?
8 Pi horn and woofer? [message #62278] Sun, 04 April 2010 11:45 Go to next message
Hi Wayne,
Does the 8 Pi use the same midhorn as used in the 7 Pi corner speaker? If not, could you outline some of the differences?
Also, is the 10" Eminence woofer used in the 8 Pi the same as used in the 7 Pi corner speaker?
Thanks
Norris
Midhorn information [message #62279 is a reply to message #62278] Sun, 04 April 2010 12:34 Go to previous message
The midhorn in the eight π is the same as the midhorn in the six π and seven π loudspeakers. The driver used in the six π and seven π cornerhorns is usually the Delta 10 though, while the driver used in the eight π is the Alpha 10.
The eight π loudspeaker was actually an afterthought, sort of taking the place of what would have been a five π cornerhorn. The Alpha 10 won't handle quite as much power as the Delta 10, and isn't as well suited as a dedicated midrange. But its electro-mechanical properties make it perfect for use as a midwoofer, or for rear-tuning for bass while front loading for midrange with the horn. More information in the links below:
Previous Topic: Just scored a pair of 3pi speakers!
Next Topic: Just received a set of 2 Pi's ...
Current Time: Fri Nov 06 06:57:08 CST 2026
