Home » Sponsored » Pi Speakers » 3 Pi subwoofer mounting question (Leave or remove gasket?)
3 Pi subwoofer mounting question [message #62087] Sun, 14 March 2010 22:35 Go to next message
Hello All,
The LAB 12 woofers came from the factory with laminated paper gaskets glued to the underside of the mounting surround. Should this be removed and the woofer be mounted directly to the cabinet or left in place as a spacer? Does it make any difference? Thanks.
Re: 3 Pi subwoofer mounting question [message #62090 is a reply to message #62087] Sun, 14 March 2010 23:13 Go to previous message
Those gaskets sometimes matter when horn loading, but not when used as a direct radiator. It's usually a clearance issue. In all my designs, I leave the attached gaskets in place, but I don't use the extra one packaged with the driver.
Previous Topic: Impressions and Recommendations - 3pi and 4pi variants
Next Topic: mid horn plans
Current Time: Thu May 02 13:26:19 CDT 2024
