| 7PI midrange horn box volume [message #62076] |
Sun, 14 March 2010 09:01  |
hornT
Messages: 6 Registered: March 2010 Location: Denmark
Esquire |
Does anyone have the box volume of the 7Pi midrange horn?
Does flat frequency response really exist?
- and is it equal to perfect sound?
| Re: 7PI midrange horn box volume [message #62081 is a reply to message #62079] |
Sun, 14 March 2010 14:04   |
hornT
Esquire |
Thanks but I've already built the speakers and they sound great!
I'm thinking about trying out some different 10" though...
Apart from the original filters I have a Deqx processor - so swapping drivers is easy.
I've been thinking about this one:
http://www.usspeaker.com/beyma%2010MI100-1.htm
- but it needs 0.7ft^3
-or do you think it could work out fine in the existing cabs?
| Re: 7PI midrange horn box volume [message #62105 is a reply to message #62104] |
Tue, 16 March 2010 16:14  |
I can pull up the electro-mechanical parameters (BL, CMS, RMS and MMD) for the Delta 10 for you tonight if you want me to, but you don't really need them. Hornresp can calculate BL, CMS, RMS and MMD from T/S parameters Fts, Vas, Qes and Qms. Double-click on any of the electro-mechanical fields and it will prompt you for related T/S values. Once you've entered the T/S values, it will calculate the electro-mechanical parameters for you.
As for the Eminence Deltalite 2510, I tested with it a few years back and found it wouldn't work for me. The upper response was way too low. I think the issue was the dust cap was a mesh, sort of like the old Magnums, and didn't provide much acoustic output. The midhorn really needs the dust cap to provide some output to get any high frequencies, otherwise, there are too many path length cancellations and nothing emerges up high.
You might try it again though, sometimes Eminence changes their product manufacturing processes but retains the same name. So there can be some changes over time. I catch those in products I regularly use, but I haven't brought in a Deltalite driver in a few years.
