Home » Sponsored » Pi Speakers » 4pi design plans (4pi desing plans)
4pi design plans [message #61948] Sun, 28 February 2010 14:00 Go to next message
vann_d is currently offline  vann_d
Hi Wayne,
I've been searching the ether for high sensitivity HT speakers to DIY. Others out there seem to be years behind your designs in terms of development. The 4pi seems like the one for me. Will you send me design plans please?
I was considering your kit. The drivers and horn are available from PE. What is the benefit of ordering the kit? Assembled crossovers?
Thanks,
Vann
Re: 4pi design plans [message #61950 is a reply to message #61948] Sun, 28 February 2010 17:02 Go to previous message
You can order kits or crossovers. The advantage of buying kits is you'll get everything from a single source and the price is a bit cheaper too.
Kits come with assembled crossovers, but just the crossover by itself can be ordered too, either assembled or as a blank PCB. Crossovers come in a variety of quality options, all using high quality polypropylene caps and air-core coils. See the shopping cart for more details.
Previous Topic: 6pi Plans
Next Topic: Mid Horn Flat-Pack available?
Current Time: Wed Nov 04 18:14:33 CST 2026
