Home » Audio » Speaker » Can anyone help me find this line array elemnts. (Line array)
Can anyone help me find this line array elemnts. [message #61791] Sat, 30 January 2010 07:00
m.mardare is currently offline  m.mardare
Speakers Specs per element :
3 way Speakers:
Drives:
2X10" at 1200W/4ohm LP min sensitivity 105dB
2x6" at 400W/12ohm MP min sensitivity 105dB
2x1" at 200W/8ohm HP Min sensitivity 112 dB
Also this element need to have this maximum size:
W 72cm/28" X H 30cm/11.8" x D 50cm/19.6"
And the maximum weight must be 45Kg/100lbs
Sub
2x15" 1200W/2x8ohm (4ohm)
It must be from the same line as the 3 way elements and to use 2xNL-8MP connectors per element.
The aps
2x1200w/4ohm rms
2x700W/4ohm rms
They need to have balanced input and protection for shortcircuit with infra and ultrasounds.
Rack size 19"/2RU. No swithcing power.
We also looking for a 4 ch digital procesor with the following specs:
Selective input, crossover 6-25dB and 10 corrcection points.
Parametric EQ and 10 presets memories.
Password protected USB port, NO RS-232.
If not exact specs and alternative will be good
Thank you all Very Happy
Previous Topic: Considering first line array build
Next Topic: Optimum range JBL 2226
Current Time: Thu Apr 25 18:38:38 CDT 2024
