Wayne Parham Messages: 18695 Registered: January 2001
The JBL 2226 works pretty well in cabinets from 2.5ft3 to 5.0ft3 tuned to 38Hz. The thing is, when you change box volume, you'll naturally be forced into changing dimensions and port size and location. That will change the way standing waves line up inside the box. As a sub, it's generally not a big deal but when used as a full range speaker, this becomes pretty important.
feket663 Messages: 28 Registered: August 2009 Location: Hungary
Actually if the response go down to 40 Hz, this is enough for me. I will build an original size. Later i will build a sub, if necessary. Thank you for help and the patience.
Does the standing waves in the box affect the tone of the speaker or the sensitivity ??? Does the standing waves come back through the
cone ??? Ok I know, I ask a lot of questions. Thanks again and god bless.
Standing waves do have an influence, yes. They don't pass through the cone as much as they provide an acoustic loading for it, similar to the way Helmholtz resonance does. In fact, some speakers use this as a primary tuning mechanism.
Small boxes have standing waves at relatively high frequency, so stuffing is usually sufficient for absorbing them. The larger the box, the lower the frequency where standing waves form. Long, tall cabinets (like towers) also have pipe modes, i.e. standing waves. I used computer models on my larger cabinets and towers to help determine where to put the drivers and port so the internal standing waves didn't adversely affect response. I then verified this with acoustic measurements of a physical loudspeaker.
