Home » Sponsored » Pi Speakers » Bill Epstein: Which version of 2226 - H or J?
Bill Epstein: Which version of 2226 - H or J? [message #60463] Sat, 25 July 2009 09:54 Go to next message
Hi Bill,
Which version of the JBL 2226 did you use in your Four Pi speakers?
I am thinking about using the J, or 16 ohm version. And was hoping that you have the needed 16 ohm corrections values for the standard Four Pi crossover designed for 8 ohm 2226?
I hope all is well for you!
Thanks!
Norris
Substitution values for 2226J [message #60465 is a reply to message #60463] Sat, 25 July 2009 10:10 Go to previous messageGo to next message
I haven't tested with the JBL 2226J, but you may be able to swap it for the JBL 2226H by modifying the crossover. The woofer low-pass coils and resistors will have to be 2x size and the caps will have to be 1/2 size. The tweeter compensation needs to be reduced by 3dB too (if using the DE250-8 or PSD2002-8).
I'd go with these values when substituting the JBL 2226J:
R1 - 40Ω for DE250-8 or 30Ω for PSD2002-8
R2 - 12Ω for DE250-8 or 14Ω for PSD2002-8
R3 - 16Ω
L2 - 3mH
L3 - 1mH
C4 - 10µF
C5 - 10µF
Re: Substitution values for 2226J [message #60469 is a reply to message #60465] Sat, 25 July 2009 16:58 Go to previous message
Thanks Wayne!
Norris
Previous Topic: new 4 Pis near completion finally
Next Topic: Wayne, a question about B&C DE 250
Current Time: Sun Oct 18 21:42:30 CDT 2026
