Home » Audio » Swap Meet » Equipment for Sale (Pro Audio)
Equipment for Sale [message #59513] Wed, 24 June 2009 11:50
jim@teatown.tv is currently offline  jim@teatown.tv
We are a New York City Post-Production house, www.Teatown.tv, in business for many years and have an updated list of our excess professional equipment that we are selling.
All Offers Will Be Considered.
(Pictures are available)
Please call about any item.
Thank You,
Jim
Teatown Communications Group
212-302-0722
www.teatown.tv
Items should be considered USED, BUT VERY WELL MAINTAINED.
Soundcraft 328XD Mixer, a 32 channel mixer, has 16 Line/Mic inputs and 16 digital inputs. All of these inputs have full access to the E-strip offering 3 band fully parametric equalization, 4 auxillary sends, 2 internal Lexicon effects sends, a pan control and control over the dedicated compressor and noise gate available to each input. $1900.00
2 x Dorrough 280-D Loudness Meter Designed for measuring AES/EBU digital audio, this meter displays both peak and average, employing the same ballistics as the analog meters. Over Indication and Peak Hold are incorporated. Complies with SMPTE requirements. $ 700.00/Each
2 x Lucid AES Distribution Amplifiers 1 x Word Clock and 1 x AES3 input to 4 parallel AES3 outputs. Supports all AES3 audio or Word Clock data using 110 ohm line drivers $ 350.00/Each
2 x Event 20/20 Bi-Amplified Direct Field Monitors Controls include Input Level, LF trim, and a HF trim, and a Power On/Clip LED indicator is provided. $ 150.00
Samson Servo 150 PowerAmplifier Excellent for near field monitoring, stereo midrange/high frequency bi-amping applications and low power distribution systems. $ 120.00
Tektronix 2247A 100Mhz Oscilloscope Counter/Timer With the Tektronix 2247A you can track voltmeter measurements, visually indicate trigger level and ground, and make time measurements with cursors or alternate delayed sweep Delta Time. $1300.00
Tektronix K212 Portable Instrument Cart for Tek 2247A $ 100.00
Also available, Tektronix 1480R, 1740, 1710B, 1721, 528A
Leader LMV-186A 2 Channel AC Millivoltmeter consists of two high sensitivity Voltmeters housed in one cabinet. Voltages can be measured at the same time at two different points in the test circuit or for two separated loads. $ 450.00
3x ADC Audio Patch Panel A two rack unit, 3.5-inch, 2 by 24 longframe Pro Patchâ„¢ patchbay, 19-inch rack mountable, and 1/2 audio normalling.. It uses standard TRS (tip/ring/sleeve) 1/4" patch cords. $250/each
jim@teatown.tv
NYC
www.teatown.tv
Previous Topic: Free Khanspire Enclosures in Houston
Next Topic: Bottlehead Foreplay III Tube Preamp - For Sale
Current Time: Tue Apr 23 19:04:02 CDT 2024
