Home » Sponsored » Pi Speakers » LaScala X-over ???
LaScala X-over ??? [message #53512] Wed, 06 May 2009 14:56 Go to next message
What is the best way or the Pi-align crossover for a LaScala ? Maybe you have a schematic that you believe works best ? Thanks and God Bless!!!
Re: LaScala X-over ??? [message #53513 is a reply to message #53512] Wed, 06 May 2009 17:34 Go to previous message
Sorry, I don't do anything with Klipsch speakers. They're cool and all, but my stuff is different enough that you can't really cross-pollinate without serious modifications. If the Klipsch midhorn could be used an octave or two lower, if the tweeter horn were CD, and if the acoustic geometrical relationships were the same between them then you could use the same crossover I use in the seven π cornerhorn. But those are all pretty significant differences, enough that you can't use one with the other.
Previous Topic: Music room floor and wall treatment
Next Topic: Speaker over damping !!!
Current Time: Fri Nov 13 02:57:49 CST 2026
