Home » Sponsored » Pi Speakers » h290/driver gasket?
h290/driver gasket? [message #53458] Wed, 22 April 2009 19:04 Go to next message
reguax is currently offline  reguax
Hi Everyone
I'm building a pair of 4pi and I wonder if should I put any type of gasket between the horn and the driver?
I had some pieces of 'acoustical underlayment for laminate floor' remaining from floor installation and I uses it as gasket. It's about 2mm thick.
Is there any problem in having the driver 2mm away from the horn?
Is it better to have them face to face?
Thanks!
Re: h290/driver gasket? [message #53459 is a reply to message #53458] Thu, 23 April 2009 00:23 Go to previous messageGo to next message
The driver has a built-in gasket. I wouldn't add to that. When the driver is attached to the horn, the gasket is squished flat making the seam between driver and horn throat very small, too small acoustically to matter. If you add another gasket, that may introduce a gap. This would cause a discontinuity right at the highest pressure point. You don't want that.
Re: h290/driver gasket? [message #53461 is a reply to message #53459] Thu, 23 April 2009 14:02 Go to previous message
Ok Wayne
I will remove my gasket immediately
Thanks!
Previous Topic: 2 pi questions
Next Topic: Screw on adapter
Current Time: Tue Nov 03 20:38:14 CST 2026
