Home » Sponsored » Pi Speakers » 80 hz punch
80 hz punch [message #53404] Thu, 09 April 2009 14:35 Go to next message
how can you get more 80 hz. punch with a speaker system without losing the low end response ? Thanks
Re: 80 hz punch [message #53405 is a reply to message #53404] Thu, 09 April 2009 22:27 Go to previous messageGo to next message
If you want extra output in the 80Hz range, try a small basshorn or underdamped direct radiator tuned to 80Hz. I design my speakers for flat response but it is very easy to find alignments that tend to peak in the midbass like that.
Another thing you can do is to provide gentle parametric EQ to get the desired response.
Re: 80 hz punch [message #53406 is a reply to message #53405] Fri, 10 April 2009 01:04 Go to previous messageGo to next message
Can you make the box double reflex and tune both for 80 hz and total volume for 40 hz ??? first vol.say 3 cu. ft. second volume 1 cu. ft ?
Re: 80 hz punch [message #53407 is a reply to message #53406] Fri, 10 April 2009 10:09 Go to previous message
There you go - That'll do it.
Previous Topic: B&C DE 250 and compensation
Next Topic: prices up
Current Time: Mon Nov 23 09:51:23 CST 2026
