Home » Sponsored » Pi Speakers » Brass screws to mount drivers ?
Brass screws to mount drivers ? [message #53260] Wed, 25 February 2009 14:19 Go to next message
ports is currently offline  ports
...Has anyone tried this "tweak" ... any thoughts ?
http://www.virtualdynamics.ca/the-oddiophile-eps-1
Does the Flap of a Butterfly's Wings in Brazil Set Off a Tornado in Texas? [message #53261 is a reply to message #53260] Wed, 25 February 2009 21:14 Go to previous messageGo to next message
Re: only if you never learned about limits in math.....haha [message #53262 is a reply to message #53261] Wed, 25 February 2009 21:24 Go to previous messageGo to next message
guy sounds a little whacky, but I always use brass screws since you can darken 'em easily and they look good dark with just a touch of brass showing at the edges. I also put them in staggered and torque metal consistently, so I wouldn't know if this works or not! Flap away!
Re: only if you never learned about limits in math.....haha [message #53263 is a reply to message #53262] Thu, 26 February 2009 10:21 Go to previous message
Ok I believe that the butterfly has a bigger impact on the sound, But I would prefer the brass.
Previous Topic: Front port Vs Rear port
Next Topic: Venturi Port ???
Current Time: Thu Nov 26 17:37:04 CST 2026
