Home » Sponsored » Pi Speakers » K-33E good for subwoofer ?
K-33E good for subwoofer ? [message #53149] Fri, 30 January 2009 17:47 Go to next message
Will it work in the 30-250 Hz range at a 93 db or better Spl ?
Re: K-33E good for subwoofer ? [message #53151 is a reply to message #53149] Fri, 30 January 2009 19:35 Go to previous message
The K33 is a great woofer for use as a home hifi sub. The problem is it needs a big box to hit the low notes. It is suitable for use in cabinets from 3.5ft3 to 10.0ft3 tuned to 35Hz, but if you want to use it as a sub, the cabinet should be on the large side. That would probably make a multi-sub arrangement somewhat disagreeable, just because of the size of each cabinet. But it would work nicely otherwise.
Previous Topic: Dynaco st-70 tube amp by triode elec?
Next Topic: Speaker kit price
Current Time: Mon Oct 19 20:28:13 CDT 2026
