Home » Sponsored » Pi Speakers » Pi kits?
Pi kits? [message #53074] Mon, 12 January 2009 03:00 Go to next message
MCFive is currently offline  MCFive
What do you get when you buy a Pi kit? Do they come with plans for the cabinets? I'm interested in trying out the one or two in kit form.
Thanks.
Re: Pi kits? [message #53075 is a reply to message #53074] Mon, 12 January 2009 09:57 Go to previous messageGo to next message
breakfastchef is currently offline  breakfastchef
I recently built a pair of 2 Pi Towers. Wayne supplied the basic plans ahead of time so I could have the cabinets ready for the components. I did a lot of searching on the forum for 'best practices' to consider when building the cabinets.
Wayne supplies an easy plug-and-play solution. Everything from the binding posts for the back of the speakers to the spades you plug into the drivers are pre-wired. You just connect the spades to the drivers, drop the drivers and binding posts in the holes you cut and screw them in (you supply the screws). You even get two Pi stickers to affix to your speakers.
Re: Pi kits? [message #62647 is a reply to message #53075] Thu, 13 May 2010 19:04 Go to previous messageGo to next message
fuj32 is currently offline  fuj32
do we have do build the crossovers ourself or are they preassembled?
Re: Pi kits? [message #62650 is a reply to message #62647] Thu, 13 May 2010 20:02 Go to previous message
Crossovers are preassembled. No soldering required.
Previous Topic: 3 Pi - Could it work for me?
Next Topic: insulation for the 2pi tower
Current Time: Mon Oct 26 16:25:02 CDT 2026
