Home » Sponsored » Pi Speakers » Three pi subs 92 db ?
Three pi subs 92 db ? [message #53070] Sat, 10 January 2009 22:44 Go to next message
How do you get 92 db ? does the box add gain to the 89 db lab 12 ?
THANKS
Re: Three pi subs 92 db ? [message #53071 is a reply to message #53070] Sun, 11 January 2009 12:01 Go to previous messageGo to next message
bass reflex designs use energy from the rear of the speaker interacting with the volume of air in the port to give some additional efficiency over sealed box designs
Re: Three pi subs 92 db ? [message #53072 is a reply to message #53070] Sun, 11 January 2009 14:51 Go to previous message
You might notice the page where that spec is listed gives conditions where measurements were taken. All specs are given at 2.83v/M rather than 1w/M. The woofer is a 4Ω part, so 1 watt is dissipated with a 2.0v drive signal. Send it 2.83v and 2W is dissipated, which is 3dB higher.
Previous Topic: How Do I Connect Speaker Wire To These Spades?
Next Topic: Are tweeters and woofers supposed to be flush mounted for Pi Two kit? NT
Current Time: Tue Nov 24 17:30:54 CST 2026
