Home » Sponsored » Pi Speakers » Back to the Aikido
Back to the Aikido [message #52852] Mon, 10 November 2008 08:40 Go to next message
Finally worked up the courage to build the power supply from the schematic (first time for me to build from a schematic) Steve Brown designed for me. The HV is a CLC to a tube rectifier, the filaments a full-wave bridge with voltage divider. Almost done, just have to wire up the CRC smoother after the bridge. The 4Pis should really sing with the added gain from my 2 watt 45 amp.
Check the middle switch at the rear: it enables switching between a Russian K-40 .22uF PIO, a 2.2uF Obbligato or both in parallel for the output. A cap shoot-out with the turn of a dial!
I just had to sneek a peek at all those 6SN7s. I don't know if I'll use the 5R4 rectifier but it looks cooler than the little 5AR4 spec'd...
Stay tuned.
Re: Back to the Aikido [message #52853 is a reply to message #52852] Mon, 10 November 2008 11:16 Go to previous messageGo to next message
Looking good Bill,
I haven't looked at the Akido design lately. I was wondering if the second 6SN7 is a cathode follower? If it is, it might be fun to somehow install a switch where you can switch out the first 6SN7 gain stage.
I owned a VAC preamp several years ago that had switchable gain stages that used 12AX7's for the gain, and a 12AU7 for cathode follower. Switching out the gain stages all together was my preference, but had a slight negative gain. As with all components in the signal path, they introduce their own signature.
Keep us informed of your progress?
I am very curious of how well your 2 watts will go towards driving the Four Pi's?
I will be building a 2.5-way version of the Four Pi using 2226J's with Beyma CP-385ND 1" CD and TD-250 horn.
I am hoping two watts will be enough to get them a rocking at 100db efficiency.
Have fun!
NW
Re: Back to the Aikido [message #52854 is a reply to message #52853] Mon, 10 November 2008 11:42 Go to previous messageGo to next message
With just a passive volume pot, 2 watts gets loud enough for Dire Straits but not for the Who. Loud enough for Count Basie but not the Cleveland Orchestra, w/o serious clipping.
The Aikido is described by Broskie as "a 2 tube cathode follower with the first tube a vlotage divider of 50%, so that 50% of the PS noise is presented to the CFs grid; at the same time the 100k resistors also define a voltage divider of 505 so the bottom triodes grid also sees 50 % of the PS noise. Since both of these signals are equal in amplitude and phase, they cancel each other out, as each triode sees an identical increase in plate current."
I have no idea what any of that means...
Re: Back to the Aikido [message #52857 is a reply to message #52854] Mon, 10 November 2008 13:26 Go to previous messageGo to next message
Oooh, that's sweet, Bill! Keep us posted!
Re: Back to the Aikido [message #52858 is a reply to message #52857] Tue, 11 November 2008 14:23 Go to previous messageGo to next message
GarlandGarland is currently offline  GarlandGarland
Do let us know your impressions! I've always been intrigued by the circuit.
G.
Re: Back to the Aikido [message #52859 is a reply to message #52852] Tue, 11 November 2008 15:31 Go to previous messageGo to next message
All that work for 2 watts, It does look nice though. Hope to see pics of it when its completed.
Re: Back to the Aikido [message #52876 is a reply to message #52852] Mon, 17 November 2008 18:23 Go to previous message
Bill, your transformer 5v winding is only good for 2A, and I think the 5R4 is hotter than that. Check it out.
Previous Topic: 2 Pi Tower Build Tips
Next Topic: Move over Albert, Robert J., Lesley and Enrico
Current Time: Sun May 05 16:11:16 CDT 2024
