Home » Sponsored » Pi Speakers » pi 7 cornerhorn
pi 7 cornerhorn [message #52805] Fri, 24 October 2008 11:02 Go to next message
Larry is currently offline  Larry
wayne,
is it possible to have the plans for the pi 7 speakers? i'm really interested in this.
thanks
larry
You've got mail! [message #52807 is a reply to message #52805] Fri, 24 October 2008 12:35 Go to previous messageGo to next message
Re: You've got mail! [message #52811 is a reply to message #52807] Sat, 25 October 2008 20:07 Go to previous messageGo to next message
wayne,
thank you!
just a query - is the bass box just like a bass reflex type with some extention box? i can see a circular hole with some pipe. am i correct? what is the rectangular hole i's seeing at the rear also?
larry
Re: You've got mail! [message #52813 is a reply to message #52811] Sat, 25 October 2008 23:42 Go to previous messageGo to next message
The bass bin is a vented enclosure. The round hole is the woofer cutout and the rectangular duct is the port.
Re: You've got mail! [message #52817 is a reply to message #52813] Sun, 26 October 2008 02:12 Go to previous messageGo to next message
ok. i thought there is a smaller round duct below the driver. thanks again.
Re: You've got mail! [message #52820 is a reply to message #52817] Sun, 26 October 2008 13:11 Go to previous messageGo to next message
The six π vent is round, but the seven π duct is rectangular.
omega15 substitute [message #52825 is a reply to message #52820] Tue, 28 October 2008 00:36 Go to previous messageGo to next message
can this driver be a substitute for the omega15 as bass driver in the pi7 cornerhorn?
http://www.p-audio.co.uk/products/db_product_1_10_s15-100lf.htm
thank you.
larry
Re: omega15 substitute [message #52828 is a reply to message #52825] Tue, 28 October 2008 12:13 Go to previous message
As far as electro-mechanical specs are concerned, it looks like it will work.
Previous Topic: Hi Bill Epstein - your review
Next Topic: OEM Eminence driver C15B95 question
Current Time: Mon Nov 02 15:39:25 CST 2026
