Home » Sponsored » Pi Speakers » 7-Pi crossover points
7-Pi crossover points [message #52650] Tue, 16 September 2008 19:32 Go to next message
jimbop is currently offline  jimbop
Wayne, what are the crossover points for the 7-Pi?
Jim Dombrowski
Re: 7-Pi crossover points [message #52652 is a reply to message #52650] Tue, 16 September 2008 23:50 Go to previous message
The seven π crossover points are 250Hz and 1.6kHz.
The upper crossover is almost exactly the same as the crossover in the three π and four π speakers and for the same reason. Summing is good, response is pure and directivity is matched, providing a nice uniform pattern over a wide horizontal angle and with good spacing between vertical nulls.
The lower crossover is 1st order with a lot of overlap. We want wide overlap between midhorn and bass bin for best integration. It tends to make the transition invisible and also reduces floor bounce because of the vertical distribution of sound.
Previous Topic: Question for Bill E.
Next Topic: Heads up on Bessey K-body clamps
Current Time: Tue Oct 20 11:20:03 CDT 2026
