Home » Sponsored » Pi Speakers » 2-Pi BASS ???
2-Pi BASS ??? [message #52565] Mon, 01 September 2008 02:23 Go to next message
I tried a 1.4 cu ft box with a alpha 10 and it did not have as much low bass punch as the 1-pi , it was ok but the 1-pi sounded better in the low bass region ,How come??? I tried reversing channels and trading out locations with the same result. Would it be better to move up to maybe a 2 cu. feet box to get the same results as the 1-pi ??? Thanks.
Re: 2-Pi BASS ??? [message #52566 is a reply to message #52565] Mon, 01 September 2008 12:05 Go to previous message
The bigger the box, the deeper the bass. You can go up to 5.5ft3 on the Alpha 10.
Previous Topic: I will check the cables first...I will check the cables first...I will check the cables first...
Next Topic: Midhorn Flat Pack Kit???
Current Time: Mon Sep 07 13:31:42 CDT 2026
