Home » Sponsored » Pi Speakers » Inductor for New 4 Pi crossover
Inductor for New 4 Pi crossover [message #52521] Fri, 22 August 2008 14:40 Go to next message
GarlandGarland is currently offline  GarlandGarland
Wayne or others,
Is it possible to substitute the old .63 mH coil from the old Theatewr 4 xover for the specified .5mH coil in the new xover? If so, what sonic effect of the difference would you expect? (PSD 2002 and Eminence Delta 15)
Thanks!
Garland
Re: Inductor for New 4 Pi crossover [message #52524 is a reply to message #52521] Sat, 23 August 2008 12:16 Go to previous message
I'd probably try it just to see how it sounded. I'm not sure how much shift you'll see; My guess is it might make a slight dip in the crossover region, maybe a shift in the angle of the null angles.
Previous Topic: Is it Sunday yet?
Next Topic: Painting, fiddling and Pat Barber
Current Time: Sat Oct 17 01:29:56 CDT 2026
