If you put 4 drivers like 4 Alpha 8s in a 3 cu ft. box tuned to 55hz ,with 1 Vifa tweeter ,Would this give anymore low end or just sound the same ? wired in series/par.for 8 ohm. THANKS
Wayne Parham Messages: 19105 Registered: January 2001
I think that would overpower the tweeter. One Alpha 8 is enough. If you want to make an array using Alpha 8's, I think you'll need an array of tweeters to keep up.
