Home » Sponsored » Pi Speakers » Vifa upgrade kit
Vifa upgrade kit [message #52346] Sat, 19 July 2008 16:30 Go to next message
I already had some Alpha-8's and I couldnt find where to order the vifa tweeters and x-over on this site so i had to order from another place ,forgive me . I did order the 4-Pi x-overs. Where do you get the Pi emblem ? Another Question could you show the internal bracing on the 4-Pi's ? Thanks the 1-Pi's are Excellent!!! A+ and are probably the most overlooked speaker you have. I would not believe the sound without hearing them myself.
Re: Vifa upgrade kit [message #52348 is a reply to message #52346] Sat, 19 July 2008 16:52 Go to previous messageGo to next message
In the four π speakers, I put a cross brace between the woofer and tweeter, spanning left to right sides and front to back. As for the smaller models with the Vifa tweeters, I had the upgrade kit listed for a year or so after introducing the versions of the speakers wih the DX25. Then I removed it because all kits now come with DX25's. The upgrade kit is $30.00 per speaker if you're interested in purchasing. As for the π logo, tell me your address and I'll send you some.
Re: Vifa upgrade kit [message #52351 is a reply to message #52348] Sat, 19 July 2008 20:54 Go to previous messageGo to next message
Thanks for the reply. my address is Wayne Raisley, 5007 Salem Dr, Otisco IN 47163
Re: Vifa upgrade kit [message #52352 is a reply to message #52351] Sat, 19 July 2008 23:18 Go to previous message
I'll put a couple decals in the mail right away.
Previous Topic: 4-Pi Phase shift???
Next Topic: Pi Speakers
Current Time: Sat Nov 07 04:20:40 CST 2026
