Home » Sponsored » Pi Speakers » Wayne, can I have the plans for the seven pi 18?
Wayne, can I have the plans for the seven pi 18? [message #52247] Thu, 26 June 2008 13:07 Go to next message
xcortes is currently offline  xcortes
I have a 2241h looking for a home.
Thanks,
xavier
Please send me your E-Mail address [message #52249 is a reply to message #52247] Thu, 26 June 2008 13:51 Go to previous messageGo to next message
When I get your E-Mail address, I'll send the plans right out.
Here's a descriprtion of the seven π bass bin for the JBL 2241:
Re: Please send me your E-Mail address [message #52250 is a reply to message #52249] Thu, 26 June 2008 13:54 Go to previous messageGo to next message
I sent you a message. Thanks
One question: how high can I expect the cornerhorn to reach?
π cornerhorn behavior [message #52253 is a reply to message #52250] Thu, 26 June 2008 18:18 Go to previous messageGo to next message
The π cornerhorn reaches pretty high because of its simple design. It provides useable output over the woofer's entire range.
On casual inspection, one would expect a self-cancelling reflection notch in amplitude response at the frequency where the woofer was 1/4λ from the wall. When I first designed it, I intended to always crossover below that frequency or at least near it, using the notch to help rolloff the woofer.
As it happens, there is no well-defined self-cancelling reflection notch. It does not happen because of the numerous path lengths from all the possible wavefront angles from edge to edge. Instead, the 1/4λ boundary frequency marks the start of a transition from point source to multi-path dense interference, which reduces output slightly but at a fairly uniform amplitude.
In fact, I experimented for a few years with a two-way design because of this property. It works pretty well, to be honest, better than you would expect. But I prefer to crossover as the original design intended, below the 1/4λ boundary frequency.
That works out very well, because having two overlapping sound sources stacked vertically at low midrange frequencies helps prevent floor bounce from either one. They combine coherently on the forward axis and off-axis along the horizontal plane, and in the vertical plane the two interact with each other and with their ground reflections to act like four sound sources.
Wide overlap works best, because it allows the woofer and midrange to blend with each other. As frequency rises, past the 1/4λ boundary frequency, the interactions between reflections become complex. But this happens to be pretty close to the Schroeder frequency, where room modes become so closely spaced as to become indistinguishable. Above that frequency, sound acts more as a reverberent field and less as discrete room modes.
thanks (nt) [message #52254 is a reply to message #52253] Thu, 26 June 2008 18:40 Go to previous message
Previous Topic: New to forum, building 2Pi towers
Next Topic: 7 Pi bass cabinet
Current Time: Sat Nov 07 16:54:11 CST 2026
