Home » Sponsored » Pi Speakers » mid horn
mid horn [message #52132] Sun, 18 May 2008 19:41 Go to next message
David Morehouse is currently offline  David Morehouse
Can I curve the front edge,top and bottom of the mid horn. Layout as per plans then add approx.2 inches to the center of the front lip of the top and bottom pieces and curve back to the original location where they meet the side pieces. This is for cosmetic purposes only.
Re: mid horn [message #52135 is a reply to message #52132] Sun, 18 May 2008 22:22 Go to previous message
You betcha. That will be just fine.
Previous Topic: Hybrid 4pi bass bin crossover
Next Topic: 3 way xover
Current Time: Sun Nov 08 10:17:07 CST 2026
