low mid tapped horn [message #52078] |
Sat, 26 April 2008 13:55 |
iluvaudio
Messages: 2 Registered: May 2009
Esquire |
Hello, I see that the tapped horn is starting to gain popularity in the pro sound realm and seem to do a great job in the low bass region. I am thinking about using the JBL 2206H for the low mid section playing from 100Hz to 500Hz. Do you think that the tapped horn approach would be effective in this frequency range?
100Hz Midhorn [message #52088 is a reply to message #52086] |
Sun, 27 April 2008 15:43 |
Messages: 18686 Registered: January 2001
A midhorn used from 100Hz up should be about 3 feet long and needs a fairly large mouth. You can try different configurations in Hornresp to see what you can come up. Here's one I did for the JBL 2226:
