Home » Sponsored » Pi Speakers » delta 12lf
delta 12lf [message #52064] Thu, 24 April 2008 10:30 Go to next message
David Morehouse is currently offline  David Morehouse
I currently have delta 12lf in 3.5 cu. ft. ported box tuned to 40. Can I add the mid horn and ps2002 to this. Using a active xover between bass and mid and your xover between mid and high?
Re: delta 12lf [message #52066 is a reply to message #52064] Thu, 24 April 2008 11:22 Go to previous messageGo to next message
Certainly, that would be pretty close to a six π / three π hybrid. I'll send you plans for both.
Re: delta 12lf [message #52087 is a reply to message #52064] Sun, 27 April 2008 07:41 Go to previous message
dB is currently offline  dB
David,
Check also the midhorn flat-pack kit, for a very reasonable price.
(I don't work for Wayne. I am more like you, building and experimenting. Only that when you go out and ask for prices, and ask for wood cut in a CNC, they some times ask more than double just for the work with the computer or man/hour, +you have to pay the wood.)
Previous Topic: Driver?Box plans
Next Topic: low mid tapped horn
Current Time: Fri Oct 23 11:19:10 CDT 2026
