Home » Sponsored » Pi Speakers » Lab 12 push pull sub
Lab 12 push pull sub [message #52047] Sat, 19 April 2008 02:54 Go to next message
Roland Gama is currently offline  Roland Gama
Hello Wayne!
Tried an experimental prototype sub using a pair of Lab 12 in push pull configuration. Non isobaric and reminiscent of M&K design.
About 83 litres cube with typical amount polyfill damping.
Powered it using BK elect.England subwoofer amp rated at 500 rms.
The SPL and extension is astonishingly good, Also a 12db boost at 45 Hz using Bassbox Pro simulation gives a perfectly flat in room response.
The cube measuring about 21 inch is very small and ideal for home use.
Considering builing a pair using 36mm MDF, fully braced and damped.
Await your advice and help in the project.
Roland.
Re: Lab 12 push pull sub [message #52049 is a reply to message #52047] Sat, 19 April 2008 19:03 Go to previous message
Looks pretty cool! Let us know how it sounds!
Previous Topic: IV Pi B&C DE250 driver
Next Topic: 2 PI Tower wiring and cabinet instructions/plans included?
Current Time: Fri Oct 30 01:57:20 CDT 2026
