Home » Sponsored » Pi Speakers » Replacement woofer for bose 301 ??
Replacement woofer for bose 301 ?? [message #52009] Tue, 15 April 2008 00:35 Go to next message
Sorry to bother you on this, but what is a good replacement woofer for the bose 301 2008 model??? Will any woofer work in this small of a box?
Nobody else seems to know.
Re: Replacement woofer for bose 301 ?? [message #52013 is a reply to message #52009] Wed, 16 April 2008 09:20 Go to previous messageGo to next message
crazychile is currently offline  crazychile
Unfortunately the best replacement for your Bose will come from Bose. Yes, the woofers are cheaply made but unless things have changed, they are made specifically for Bose so a generic replacement from another manufacturer will give you an even more unbalanced sound.
If these are 2008 models they are still under warranty for the original owner. If you arent the original owner try calling them and maybe they'll cover the replacement anyway.
Good Luck,
crazychile
Re: Replacement woofer for bose 301 ?? [message #52023 is a reply to message #52009] Thu, 17 April 2008 01:56 Go to previous messageGo to next message
Roland Gama is currently offline  Roland Gama
Decware does some diy replacement for Bose. Check their site if you can find something for you.
Re: Replacement woofer for bose 301 ?? [message #52056 is a reply to message #52009] Sun, 20 April 2008 16:25 Go to previous message
dB is currently offline  dB
I hope you can buy (a new one) or repair them. In the first case with 2 new drivers (for left/right) you make sure to have the same image in stereo from both, even if they are a little different.
For repairs they are lots of places in the USA/UK/Aust.
Previous Topic: Vifa DX25TG-05 vs. Vifa XT25TG30-04
Next Topic: Free Three Pi Enclosures in Houston
Current Time: Fri Oct 30 04:53:50 CDT 2026
