Home » Sponsored » Pi Speakers » Omega/DE250 Crossover Wired For BiAmp
Omega/DE250 Crossover Wired For BiAmp [message #51872] Tue, 04 March 2008 00:27 Go to next message
DrD is currently offline  DrD
Hi Wayne
I think this pairing needs to be tried in an open baffle. A serious, but scaled down OB, biamped, active EQ on the bass driver, and a little SET amp with gain control on top, I heard the DE250 and it rips. It is lovely. No zing no ting. It lives up to its growing reputation. Can bi amp be an option here? I would likely use a 90' waveguide.
Re: Omega/DE250 Crossover Wired For BiAmp [message #51873 is a reply to message #51872] Tue, 04 March 2008 11:21 Go to previous message
Biamp is an easy option. Just make external connections for the crossover. That's how we make the six π, seven π and any other speaker with an externally mounted tweeter. We install the crossover in a small cabinet and make all connections outboard. This makes it easy to biamp or triamp instead.
Previous Topic: Any advantage of lower xover point and larger CD 1.4 - 2" with Four-Pi?
Next Topic: Weak Joint
Current Time: Thu Oct 15 22:44:50 CDT 2026
