Home » Sponsored » Pi Speakers » Question about placement/positioning of Theater 4's
Question about placement/positioning of Theater 4's [message #51866] Mon, 03 March 2008 16:36 Go to next message
jimbop is currently offline  jimbop
I have a pair of Theater 4's that I've moved into a new room (14.5' wide x 20' deep). The speakers are on the short wall, and my chair is about 11' from the front of the cabinets. What's the recommended placement and position for optimum soundstage?
Re: Question about placement/positioning of Theater 4's [message #51867 is a reply to message #51866] Mon, 03 March 2008 16:57 Go to previous message
I would put them within two feet of each corner, angled inwards from 30° to 45°. If the room is nearly square, then toe-in 45°. If very long and deep, then toe-in angle should be less.
This placement will give you a nice, large "sweet spot". Best imaging is anywhere that is equidistant between speakers within 40° from the axis of each one. At high frequencies, there is about +/- 20° vertical pattern, so the speakers will sound great seated even at fairly close range. Best sound while standing needs to be done from a few feet back.
Previous Topic: midbass horn
Next Topic: Email Problem
Current Time: Thu Nov 12 03:47:51 CST 2026
