| Re: Pi mid horn vs. Klipsch Lascala [message #51607 is a reply to message #51605] |
Sat, 15 December 2007 18:30   |
boblaz
Messages: 12 Registered: May 2009 Location: Radcliff, Kentucky
Chancellor |
Wayne, What is included in the 10" wood midrange kit. How much is the horn flat pack + 10" eminence driver. Actually what I want is the cost of a kit with the 10" horn midbass, high frequency compression tweeter, plus crossover for this setup. I want to integrate this with the Lascala bass horn.Thanks Robert
| Re: Pi mid horn vs. Klipsch Lascala [message #51609 is a reply to message #51607] |
Sun, 16 December 2007 09:28  |
The midhorn flatpack kit includes the four flare sides and the throat plate plus Miller dowels for easy assembly. You don't need clamps with this setup because the Miller dowels hold everything in place.Cost depends on the wood chosen. A kit like you're talking about would be about $350-400, depending on the wood you pick.
