Wayne Parham Messages: 19103 Registered: January 2001
It depends where you will be using the horn. If you plan to use it out in the open but standing on the ground, model it in half space. It will be close enough to the ground to get some loading at the lowest frequencies. Changes like this are pretty substantial though, so I wouldn't expect it to act the same.
