Home » Sponsored » Pi Speakers » Matching center speaker to 7Pi
Matching center speaker to 7Pi [message #51053] Sun, 06 May 2007 08:31 Go to next message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne.
I want to make the center speaker a match for the 7Pi, and I want it to look nice too.
So if I make it the same width and depth, as the midhorn, and considering the height that will fit under the screen, it will turn about to be around 145 liters.
The 7Pi is about 60liters ex. port, the port is 140cm2 x 38cm, giving a tuning of about 36hz.
1. What tuning should I go for in the center speaker, when I don´t have the corners to help out in the low bass.
2. Should I fire it towards the wall, and make some sort of reflector ?
Regards
Kim
Re: Matching center speaker to 7Pi [message #51057 is a reply to message #51053] Sun, 06 May 2007 22:47 Go to previous message
I'd go with a four π of the same series. That's usually a pretty good match.
Previous Topic: One Pis done
Next Topic: Plans for a Pro 7's and Pro 7 18's
Current Time: Thu Nov 26 07:19:49 CST 2026
