Home » Sponsored » Pi Speakers » Two unrelated questions for Wayne
Two unrelated questions for Wayne [message #50722] Wed, 21 February 2007 07:28 Go to next message
xcortes is currently offline  xcortes
I just couldn't find R11 or R13 insulation down here. I found 1" fiber glass insulation and I intend to use it for my pi fours. Should I use two layers to approximate the thickness or R11?
Also, in relation with the pi nines. Are they designed with a compensation network for the tweeters or the 2" drivers and horns do not need it.
Thanks,
xavier
ps. Making progress with my pi HT setup. Today and tomorrow I'll put together the crossover networks. I also couldn't find peggged board so I'll mount them on thick corrugated cardboard.
Re: Two unrelated questions for Wayne [message #50723 is a reply to message #50722] Wed, 21 February 2007 08:39 Go to previous messageGo to next message
I'd use two sheets of the 1" insulation you found. The 9π tweeter horn won't have passive EQ because it is expected that will be done upstream.
Re: Two unrelated questions for Wayne [message #50724 is a reply to message #50723] Wed, 21 February 2007 09:32 Go to previous message
"The 9π tweeter horn won't have passive EQ because it is expected that will be done upstream". You mean the speakers will be triamped? Love that.
thanks
Previous Topic: pi studio two
Next Topic: Eminence APT-50 super tweeter
Current Time: Mon Nov 23 03:06:14 CST 2026
