First listen to the 3-way; I call them the...... [message #50531] |
Sat, 13 January 2007 20:38 |
Bill Epstein
Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
Illuminati (2nd Degree) |
BatSpeakers: The 2226's cut off at 350Hz have the best sound I've ever heard from them. The 2123 is the kid in the front row waving his hand in the air; "ooh, ooh, call on me!!!" They definitely need to be padded down a little.A 1 henry series coil didn't do anything but introduce some distortion so I'll try something like a 10 ohm shunt and a 20 or 30 ohm series resistor. It needs to come down about 4 dB. The Fountek CD-2 ribbon lends some nice air and, I think, a bit of transient oomph way up high on cymbals. hard to tell though with the 'bad boy' waving his hand around. I wonder if taming the mid-driver was what led Dave Cope to call off his FrankenSpeaker project with the TADs?
Re: Question about attenuating the 2123 [message #50532 is a reply to message #50531] |
Sun, 14 January 2007 02:24 |
Bill Epstein
I'm looking at the Pi compenation networks. 600Hz, 6dB calls for R1 = 8ohm and R2 = 16 ohm with 4.7uf by-pass on R1. Is that where I want to be attenuationg the overall output from 300 to 4000 Hz?
Re: First listen to the 3-way; I call them the...... [message #50533 is a reply to message #50531] |
Sun, 14 January 2007 10:28 |
spkrman57
Messages: 522 Registered: May 2009
Illuminati (1st Degree) |
Bill, Have you confirmed proper polarity and voice coil alignment for proper phase results? I don't understand how a coil in series with the 2123 introduces distortion??? Run your coil in series with the 2123 with a 20 ohm resistor across the terminals of the 2123 and tell us what happens! Ron
Re: Question about attenuating the 2123 [message #50535 is a reply to message #50532] |
Sun, 14 January 2007 11:43 |
Messages: 18688 Registered: January 2001
Oooh, that's sweet, Bill. You have all the right stuff for a great speaker.For your midrange driver, you don't want to use the attenuator configuration I use for compression tweeter padding. It is a special case where I want a specific load on the crossover that makes it underdamped. I do this to create a shelved region for a couple of octaves between the crossover frequency and the HF range where augmentation begins. So this kind of network allows some peaking to develop. Instead, you want something closer to what I use on the midhorn in the seven π. Its job is to provide pure attenuation without allowing peaking or providing excessive damping. It provides a little bit of damping, but it is pretty much a matched load. I suggest the same thing would probably be good in your speaker. Try this and see how it sounds for you: Assuming your midrange is an 8Ω 2123H, use an 8Ω resistor in shunt across the midrange driver and a 4Ω resistor in series before that. If it's a 16Ω 2123J, use a 16Ω shunt and 8Ω series resistor instead. For a crossover, try running it wide open and see how that sounds as a full range. You might add a coil to tame the top end a bit. Start off with values around 0.5mH for a 2123H or 1.0mH for a 2123J. I wouldn't use a capacitor, allowing the woofer and midrange to overlap. They're close enough they'll act as a single source at low midrange frequencies anyway because they'll be within 1/4λ of each other.
Re:Very bad news about the 2123's [message #50541 is a reply to message #50540] |
Tue, 16 January 2007 15:24 |
What a bummer! The recone kit is available, but it's pricey.What caused them to fail? I know you aren't running big amps. Maybe they were blown when you got them? Did you buy them used?
