Home » Sponsored » Pi Speakers » Compact version of 6Pi / 7Pi (Choosing between 6Pi and 7Pi and wife compatible modifications)
Re: Compact version of 6Pi / 7Pi [message #99723 is a reply to message #99722] Sat, 22 August 2026 09:43 Go to previous messageGo to next message
That's a very attractive loudspeaker, and looks to me like it will work well.
My gut feel is that it will perform much like the ones I make - having constant directivity from the Schroeder frequency upwards - offering uniform coverage with good imaging throughout the room beyond the area where the forward axes cross.
I do think you'll want to incorporate subs though.  Both for extension and for modal smoothing.  I realize you have modified the bass bin to provide deeper extension but room modes dominate so multisubs are still most beneficial.
I find it best to do large projects in stages.  First build the mains.  Then build subs.  Then maybe surrounds.  That way, each step gives satisfaction and lets you appreciate what you've done.  And each subsequent step can be evaluated incrementally, giving you a thorough understanding of what has been gained.  Plus it's much easier on the budget of both time and money.
So maybe later you can build some attractive end tables that serve as secret subwoofers.
Re: Compact version of 6Pi / 7Pi [message #99741 is a reply to message #99723] Wed, 26 August 2026 14:00 Go to previous messageGo to next message
Henner is currently offline  Henner
Thank you for your answer and thoughts, Wayne.
I will go with your recommendation to seriously consider integrating a sub and also to adjust the angle so that the forward axes cross before the listening position.
Would you be so kind as to share your plans for the 3Pi subwoofer with me?
I thank you again for your invaluable service to the DIY community!
Re: Compact version of 6Pi / 7Pi [message #99743 is a reply to message #99741] Wed, 26 August 2026 21:25 Go to previous messageGo to next message
You've got mail!
Re: Compact version of 6Pi / 7Pi [message #99751 is a reply to message #99743] Mon, 31 August 2026 16:40 Go to previous messageGo to next message
Thank you Wayne.
You have no idea how much joy this gives me. You are just awesome!
Cheers, Henner
Re: Compact version of 6Pi / 7Pi [message #99752 is a reply to message #99751] Mon, 31 August 2026 17:05 Go to previous message
You've very kind.
I enjoy seeing your progress!
Previous Topic: 4 Pi build Ferrari Red
Next Topic: Pi Speakers FAQ
Current Time: Fri Sep 04 16:02:20 CDT 2026
