Home » Audio » Source » Crackly Speakers
Crackly Speakers [message #98559] Tue, 13 May 2025 19:27 Go to next message
Chloe is currently offline  Chloe
I own two speakers that have both suddenly started to sound crackly and distorted. I've been told that the problem may be the receiver and that replacing it would fix the issue. Is this correct, or could there be a different issue?
Re: Crackly Speakers [message #98564 is a reply to message #98559] Wed, 14 May 2025 14:36 Go to previous messageGo to next message
Connect the speakers to a different system to know for sure.  If the noise goes away, then the problem was in the receiver or the source.
Re: Crackly Speakers [message #98565 is a reply to message #98559] Thu, 15 May 2025 14:49 Go to previous messageGo to next message
And then after you fix them, put an old 33 on the turntable to revisit that good, old-fashioned crackly sound.
Laughing
After all these years, I still know what that sounds like.
Re: Crackly Speakers [message #98567 is a reply to message #98565] Fri, 16 May 2025 14:45 Go to previous messageGo to next message
So true!
Re: Crackly Speakers [message #99097 is a reply to message #98567] Sun, 16 November 2025 09:18 Go to previous message
Helen is currently offline  Helen
Oh, that sounds frustrating! I’m not an expert, but from what I’ve read, crackling and distortion can come from a few things. It could be the receiver, especially if both speakers started acting up at the same time. But it might also be the wiring, loose connections, or even the speaker components themselves. I’d probably check all the cables and connections first, and if those are fine, then look into the receiver. Sometimes just cleaning the contacts can help too.
Previous Topic: Repairing old CDs and DVDs
Next Topic: Cassettes
Current Time: Mon Nov 16 14:00:04 CST 2026
