Home » Audio » Pro Sound » Microphone Options for Twitch
Microphone Options for Twitch [message #97587] Thu, 04 April 2024 05:35 Go to next message
AcousticJack is currently offline  AcousticJack
I would like to start streaming on Twitch while playing and I'm thinking about the Blue Yeti as a professional microphone, what are your thoughts on this? Is it worth the money or is it overhyped?
Or would it be better to buy good quality headphones with a microphone? I'd appreciate any ideas Smile
Re: Microphone Options for Twitch [message #97607 is a reply to message #97587] Sun, 07 April 2024 10:02 Go to previous messageGo to next message
I like to use a separate mic and headset, but it's really just a personal preference. I like different styles of each and find it difficult to find a perfect match in one headset.
I'm not a Twitch streamer, but I broadcast things regularly for my music class. The Blue Yeti used to be my go-to choice, but I've recently switched to the Shure MV7 because it seems to do better with background noise. I have a busy household with kids and pets, so dealing with background noise is a must for me, unfortunately. Don't hesitate to go with the Blue Yeti, though. It produces crisp audio, and it's a quality microphone at a decent price. It's also durable. I must've knocked the mic off my desk a million times, yet it still performed well.
Re: Microphone Options for Twitch [message #98170 is a reply to message #97587] Sun, 29 December 2024 19:33 Go to previous messageGo to next message
My oldest son is a Twitch streamer. He mostly streams himself playing Call of Duty and Fortnite. I believe he switches between a Blue Yeti Nano and a Shure SM58. I'll warn you, though, that creating a decent stream is a learning curve. The best mic in the world won't help you if you have slow internet speeds and glitchy software.
Re: Microphone Options for Twitch [message #98377 is a reply to message #97587] Wed, 19 March 2025 10:23 Go to previous messageGo to next message
Chloe is currently offline  Chloe
Personally, I've been using the FIFINE A6T for almost three years. It has a very nice sound quality; better than some other microphones that I've seen. Although, the build and sturdiness of the stand isn't terrible, but it's not the best. I still recommend checking it out.
Re: Microphone Options for Twitch [message #98426 is a reply to message #97587] Tue, 08 April 2025 02:06 Go to previous message
Blue Yetis are decent.  There are a lot of great models out there that will fit the bill.  I suggest you try different versions to see which works best for you.
Previous Topic: Easy to play harmonica
Current Time: Mon May 12 17:13:33 CDT 2025
