Home » Audio » Source » to RIAA or not
to RIAA or not [message #97930] Wed, 07 August 2024 21:41 Go to next message
Hi everyone. This has likely been covered somewhere in the past but as gear and software improved I figured I would inquire again. Most newer ADCs seem to have a huge S/N ratio. Usually a noise floor better than -100db and likely a headroom of at least 20db. So if the slope of the RIAA curve is about 40db it would seem reasonable to expect that the output from a phono cartridge would fit with room to spare. From my readings etc it appears that the absolute max dynamic range of an LP is about 75 db and most are far less it might seem reasonable to do the RIAA conversion in a PC. Any thoughts?
Re: to RIAA or not [message #97933 is a reply to message #97930] Thu, 08 August 2024 08:43 Go to previous messageGo to next message
I think you're proposing to create an RIAA curve using a digital filter. Is that what you're saying? If so, I agree. That would be easy to do.
But I can already hear screams of horror from the analog enthusiasts. Laughing
Re: to RIAA or not [message #97934 is a reply to message #97933] Thu, 08 August 2024 11:00 Go to previous messageGo to next message
Is the Parks DSP phono preamp along those lines?
https://positive-feedback.com/reviews/hardware-reviews/the-parks-audio-puffin-phono-stage-etc-etc-etc-etc-etc/
Re: to RIAA or not [message #97937 is a reply to message #97934] Thu, 08 August 2024 21:25 Go to previous messageGo to next message
Hi, I suspect it does that. I have a number of ADCs and DACs plus lots of software to fool around with. A quick check of Audacity indicated it was easy to create a RIAA eq. I intend to try feeding directly from a cartridge into a SIIG ADC and then save as a wave file at 34/96. Using that in Audacity apply the eq and adjust the level as needed. It would seem to be a way to do it. Dynamic range on the SIIG is 108 so it should be adequate. More to follow....
Re: to RIAA or not [message #97939 is a reply to message #97937] Fri, 09 August 2024 09:32 Go to previous messageGo to next message
GoFar you're like Chuck Berry's song Nadine. Always up to something new.
Re: to RIAA or not [message #97942 is a reply to message #97939] Fri, 09 August 2024 21:14 Go to previous messageGo to next message
Hi, I have been called a number of less flattering things. You should see some of the things I tried that didn't work. I figure if I have the idea and the parts to try it why not. It is how I learn new things. Very Happy
Re: to RIAA or not [message #98366 is a reply to message #97930] Mon, 10 March 2025 16:40 Go to previous messageGo to next message
Am I the only one who opened this thread believing it to be a discussion about pirating?  I was ready to share my tips with gofar99, with a caveat that I haven't pirated since my teens, so my info might not be up to par.  I figured you had gotten a threatening letter from the RIAA.
Re: to RIAA or not [message #98367 is a reply to message #98366] Tue, 11 March 2025 10:22 Go to previous message
Hi, Not pirating...but trying to find the best way to play LPs.  Basically is a digital filter as good as or better than an analog one.
I have never heard of anyone getting a letter from the RIAA.  I haven't even heard of the issue for over 30 years possibly 40.  The most current issue  similar is capturing HI-rez stuff from the web.
Previous Topic: Longest you've used a cartridge
Current Time: Sun Mar 23 19:23:30 CDT 2025
