Home » Sponsored » Pi Speakers » Three Pi Sub Plans (build three pi sub using Lab12)
Three Pi Sub Plans [message #95156] Mon, 31 January 2022 12:48 Go to next message
gnanamu is currently offline  gnanamu
Wayne,
I have access to Lab 12. Can you please share the three pi sub plan?
Also, can I make the sub a little shallow say 15" instead of 20", and increase the width or height to compensate by keeping the internal volume the same?
Thank you,
Gnana
Re: Three Pi Sub Plans [message #95158 is a reply to message #95156] Mon, 31 January 2022 14:48 Go to previous message
You've got mail!
And - yes - you can modify the dimensions as long as you maintain the internal volume. You can't usually do that with mains - internal standing waves change if dimensions change - but in subs, the wavelengths are much larger than the box, so they don't line up inside.
Previous Topic: What DAC are you using?
Next Topic: Pi Horn makes weird noise.
Current Time: Tue Apr 23 22:13:49 CDT 2024
