Home » Audio » General » Sound Machines for a Better Sleep
Sound Machines for a Better Sleep [message #94690] Wed, 27 October 2021 02:52 Go to next message
Spotifier is currently offline  Spotifier
I came across this while searching for how to sleep better. Seeing that this is a thing tells a lot about how people are having a hard time fixing their sleep. There are sounds like these on our phones, but relying on that can lead you to use other apps. Since these are below $50, it's not so bad to try and have one. Do you think it's practical, though?
Re: Sound Machines for a Better Sleep [message #94705 is a reply to message #94690] Thu, 28 October 2021 21:29 Go to previous messageGo to next message
Zart is currently offline  Zart
It seems to me that it's like the opposite of an alarm clock. Maybe people who don't have noise-proof rooms will find this helpful. I wouldn't buy it, though, because I can sleep easily once the lights are out.
Re: Sound Machines for a Better Sleep [message #94713 is a reply to message #94705] Fri, 29 October 2021 15:03 Go to previous messageGo to next message
It depends on what they sound like. I've found some that are incredibly obnoxious, like the ones that make white noise. I can handle a good rainstorm or ocean waves though.
Re: Sound Machines for a Better Sleep [message #94774 is a reply to message #94690] Thu, 11 November 2021 08:33 Go to previous message
Souldude is currently offline  Souldude
It's practical for our times because lots of people have a hard time getting some good sleep. We might only be underestimating sleep's importance, but buying anything to improve that should be a must.
Previous Topic: Take It To Washington
Next Topic: Apprpriate for all ages.
Current Time: Fri Jul 18 17:43:35 CDT 2025
