Home » Sponsored » Pi Speakers » Amp Camp Amp
Amp Camp Amp [message #93422] Sat, 03 April 2021 09:28 Go to next message
Jensen is currently offline  Jensen
I'm looking for a fun project amp to drive my 4pi speakers. Thinking of building a pair of Amp Camp amps to run as monoblocks.
https://diyaudiostore.com/collections/frontpage/products/amp-camp-amp-kit?variant=7072933085218
They're 15 watts of class A power and supposed to be able to generate "sufficient" volumes when paired with "sufficiently sensitive" speakers. Would these be a good fit? Any feed back or alternate suggestions are appreciated.
Re: Amp Camp Amp [message #93423 is a reply to message #93422] Sat, 03 April 2021 15:18 Go to previous messageGo to next message
I think that'll work very nicely. I run a pair of four Pi loudspeakers on an Audio Note SET amp that has about the same output drive level. It doesn't shake the house but gets loud enough to enjoy just about anything, even action scenes for home theater.
Re: Amp Camp Amp [message #93430 is a reply to message #93422] Sun, 04 April 2021 13:23 Go to previous messageGo to next message
Hi,
Here is my feedback and alternate suggestions.
I had ACA mono blocks about 1 year ago. I purchased the kits new, and had a qualified professional build them. His labor cost was about $325. Worth it for me. I am not a builder and wanted them done right. They were built as mono blocks, not stereo that can switch to mono. I had them built differential, balanced. I have a balanced preamp. I never thought they would be my only amps, but wanted to try them out. And not too pricey for class A.
I sold them after about 1 year of ownership. I have efficient speakers, much like Pi 3 or 4. But the amps did not provide the kind of dynamics I wanted. I like some punch and a big sound, in a medium big room. Overall, just too mellow, or laid back for me. They did sound good. Very smooth. But in the end, I just wanted more head room. I always wondered if the laptop style power supply was limiting some of the amp's dynamics and punch. I don't know.
Two alternatives come to mind, but not kits to build.
After I sold the ACAs, I purchased a used Ayre V3 amp. This used amp was priced just $200 more than I had in the kits with build cost. Totally different amp sound. Very big and dynamic. Also very quiet with he chokes Ayre uses in the power supply. The V3 is fully balanced. And some class A output.
The other suggestion is a Schiit Audio Aegir. This is a low power class A amp. The new price is about the same a 2 ACA kits. And if someone wanted more power, buy 2 and run mono. I have not heard these, but they look interesting at a good price.
In the end, you may enjoy building the kit. I am a big fan of N. Pass, and all the First Watt designs. I had a F5 about 10 years ago.
Tom
Re: Amp Camp Amp [message #93436 is a reply to message #93422] Mon, 05 April 2021 07:12 Go to previous messageGo to next message
Thank you both for the replies. As a reward for my indecisiveness, this topic has become irrelevant. The ACA's a now sold out. I'll look into the Ayer and my be back with more questions. Cheers, J
Re: Amp Camp Amp [message #93437 is a reply to message #93422] Mon, 05 April 2021 09:56 Go to previous messageGo to next message
One more I just thought of, for DIY build, is Neurochrome Modulus. Lots of positive reviews.
https://neurochrome.com/
Re: Amp Camp Amp [message #93445 is a reply to message #93422] Thu, 08 April 2021 13:58 Go to previous messageGo to next message
docjrev is currently offline  docjrev
Hi Jensen,
Here is my experience. I have 2 ACA amps configured in mono driving my Pi 4s with JBL woofers and B&C 250 tweeters. Contrary to what Tom stated above, my ACA monos can drive my Pi 4s brilliantly. I listen around 80-85 db 8 feet from my Pis. There is no loss in dynamics and I can drive the Pis louder if I wanted.
However, I also built an Aleph J and an M2x Pass amps. These 2 amps sounded different on the Pis. Better than the ACA? Definitely, but they are also bigger amps with 25 watts power per channel.
I think you will enjoy the ACA in your Pis if you will build them. You absolutely need to configure them as monos (bridged or parallel). If ever, try building the ACA amps with premium parts. In my ears, the ACA amps with premium parts sounds way better than the ordinary ones.
Godspeed.
Re: Amp Camp Amp [message #93447 is a reply to message #93422] Thu, 08 April 2021 15:35 Go to previous messageGo to next message
Thank you for the feed back. Its appreciated. I'll let the board know where I net out. Cheers, J
Re: Amp Camp Amp [message #93454 is a reply to message #93422] Fri, 09 April 2021 11:51 Go to previous message
Any feed back on the Hypex NC400s? Very reasonable price and more of a Lego than a diy project. If you listen to the science crowd, they approach "perfect".
Previous Topic: 4 Pi Build in San Luis Obispo - Flush Mounting and Bracing
Next Topic: Three Pi Update
Current Time: Thu Apr 15 09:49:58 CDT 2021
