Home » Sponsored » OddWatt Audio » Phono Preamp First Look
Phono Preamp First Look [message #91619] Tue, 24 March 2020 15:33 Go to next message
Hi Everyone. Second try at posting this. First time was a bit scrambled. Anyhow the phono preamp now is reality and I am happy with it. It has been a long road but IMO worth the many iterations and problems with it. It is quiet, has exceptional response (+/- 0.3 db 20HZ to nearly 30KHZ) and sounds quite lovely IMO. It does both MM/MI and LOMC (with built in Lundahl SUTs). If LSAF is a go and we feel safe attending it will be the main exhibit as all other gear is largely the same as in the past. I will probably bring my personal gear as opposed as kits just to add variety.
/forum/index.php?t=getfile&id=2539&private=0
/forum/index.php?t=getfile&id=2540&private=0
/forum/index.php?t=getfile&id=2541&private=0
/forum/index.php?t=getfile&id=2542&private=0
/forum/index.php?t=getfile&id=2543&private=0
  • Attachment: pp1 front.jpg
    (Size: 90.83KB, Downloaded 97 times)
  • Attachment: pp1 back.jpg
    (Size: 100.99KB, Downloaded 92 times)
  • Attachment: PP1 inside.jpg
    (Size: 307.44KB, Downloaded 96 times)
  • Attachment: PP1 open.jpg
    (Size: 216.49KB, Downloaded 96 times)
  • Attachment: pp1 top.jpg
    (Size: 99.83KB, Downloaded 95 times)
Re: Phono Preamp First Look [message #91622 is a reply to message #91619] Wed, 25 March 2020 08:08 Go to previous messageGo to next message
Sweet! That really looks nice, Bruce. Can't wait to hear it at LSAF 2020 in June!
Re: Phono Preamp First Look [message #91623 is a reply to message #91622] Wed, 25 March 2020 13:22 Go to previous messageGo to next message
Hi One thing that may not be obvious in the photos is this thing is big. 17 X 12 X 3. It weighs about 10 pounds. Since we wanted to have the best internal arrangement as was reasonable we spread things out. Customization is probably in the wind for users. Various Lundahl SUTs fit the same foot print and various step up gains are possible. Everything from 5 to 32. Various loadings are built in already. Some variation of coupling capacitors is possible. Some however are more sensitive to hum and may not be a good choice. The Russian K40Y-9s in the photos are paper in oil and sound quite nice IMO. Otherwise I would not use it in my system. We anticipate making the front panel distinctive as it is now rather industrial.
Hopefully the virus doesn't scuttle the LSAF or scare folks away from visiting it.
Re: Phono Preamp First Look [message #91624 is a reply to message #91619] Wed, 25 March 2020 17:04 Go to previous messageGo to next message
In the future, would it be possible to make MM only phono version and no MC? Bad idea?
Re: Phono Preamp First Look [message #91625 is a reply to message #91624] Wed, 25 March 2020 17:42 Go to previous messageGo to next message
Certainly. All that needs to be done when it is assembled is leave out the Lundahl SUTs, delete a few resistors and it will be MM/MI only. That was in the plans from the start. It will also make it less costly (prices not yet determined) but the Lundahls add nearly $200 to the cost.
Re: Phono Preamp First Look [message #91630 is a reply to message #91625] Thu, 26 March 2020 05:34 Go to previous messageGo to next message
I am sure your new phono preamp is superior to Groovewatt, right!
Also, a new name perhaps like Superwatt. You will think of something.
Re: Phono Preamp First Look [message #91638 is a reply to message #91630] Thu, 26 March 2020 21:25 Go to previous message
Hi, Yes. It is nameless at the moment. Suggestions are always welcome. For those of you with sharp eyes....you will notice that I have been trying different capacitors in it. One photo shows Russian K40Y-9 paper in oil capacitors the other shot shows some Audyn Caps Plus. My personal variations (earlier builds ) use Audyn True Copper Caps in one and the K40Y-9s in the other. All combinations sound great to my ears. Right now the edge seems to be for the K40Y-9s. A nice smooth but accurate sound. The Audyns are a bit more mellow to my ears.
Previous Topic: Phono Preamp nearing
Next Topic: New Amp
Current Time: Wed May 27 16:54:10 CDT 2020
